Eibach Sportlines Installed and pics
Installing them was a severe pain in the @ss, it took me like 5hrs when back in my honda days i could have changed shocks and springs all the way around in like 2hrs. Rides a little on the soft side in the back so im gonna upgrade to some better shocks. other than that im pleased.
RE: Eibach Sportlines Installed and pics
ORIGINAL: Quik
it could be if he didnt use the isolators
also it doesnt take that long to drop a stang.
the spring compressors i used were crap thats why it tooks so long.
why do you need a spring compressor on a mustang?
all you need is a jack and jack stand......lift car high enough put jack stand under it. put jack under A arm. jack it up some, remove sway bar and strut, lower the a arm then slowly remove the jack, press down on the A arm and pry the spring out some to it unsettles. use a chain or rachet strap to keep it from flying. once its unsettled pull it out and install new one. put jack under A arm and jack it up. put strut on and sway bar. your done
rear is faster, remove sway bar, remove bolt from control arm, lower it down with a jack slowly and then remove the jack and then pull out the spring. install spring slowly jack it up aligh the pig tails put bolt back in then attach sway bar...your done
so where do you need a compressor to take out spring? you dont need one for aftermarket springs that offer any kind of a drop when trying to reinstall
