running hot
running hot
Hi all. Noticed today that my tem was at the last highest bar and when i got home popped the hood coolant was lighty spraying from the cap and the overflow was full. Water pump bad? Thermostat? Im gonna replace both just wanna make sure im not missing anything. Thanks all.
If the waterpump isnt seeping coolant or squealing its ok 99% of the time but i have seen on with the impeller vanes completely rusted away from the use of water instead of coolant!
If you have a spring tester use it to see if the cap is bad, if the spring collapses under 16 lbs its bad!
be sure to bleed the air that gets in, it will make a air bubble in the motor causing it to run hot right off the bat. I learned the hard way,the problem started when radiator got low and my girl kept driving it (every few days had to add fluid, overflow had a crack in it) added fluid but ran hot as hell thought water pump was bad or blown head gasket. changed water pump was pissed when finished and still ran hot . took cap off,**** load of hot water went every where so i stuck my waterhose with the twist sprayer in the radiator for a min on full pressurew spraying water in it and looked at temp gauge and temp dropped from the l on normal to the r and was all goood then.was just air in the block. least i know no problems with water pump (new)
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
