89gt All good until I turn the Key?
Old 06-12-2011, 09:03 AM
wgreenlee4
wgreenlee4's Avatar
Question 89gt All good until I turn the Key?
I recently acquired an 89gt coupe that has been sitting in a garage for a few years and when I jumped it, all the lights were coming on nice, but when I turn the key all the way (to start) in all goes black. You then have to disconnect the battery and let it sit, doing so will make it repeat the cycle. Does anyone know why?
wgreenlee4 is offline
Old 06-12-2011, 10:36 AM
AdderMk2
Banned
AdderMk2's Avatar
put a new battery in the car before you melt something
AdderMk2 is offline
Old 06-12-2011, 11:23 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Most likely something is breaking connection. Check all the connections at the battery, starter and solenoid.
PRO50SC is offline
Old 06-12-2011, 08:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if the battery is good, check all connections, you have a bad connection / corrosion in a connection somewhere
mjr46 is offline
Old 06-12-2011, 09:33 PM
wgreenlee4
wgreenlee4's Avatar
Well, I tossed my ford focus battery in there and it started up nice, we couldn't figure out what was with that battery but whatever I'll get a new one, thanks for the help.
Old 06-12-2011, 09:40 PM
mjr46
mjr46's Avatar
it's called, the battery is bad^^^^^^^^^^^ if it frooze due to it being in a state of discharge since it was not bing used , it most likely has shorted cells in it
mjr46 is offline
Old 06-12-2011, 09:50 PM
wgreenlee4
wgreenlee4's Avatar
Well, the thing that was weird about it was that it would hold a charge, the cars lights and stuff worked, but the electrics would reject it when I tried to start it. But w/e you're right still, it was bad.
Old 06-12-2011, 10:42 PM
tohoopty
tohoopty's Avatar
they will still show they have voltage even with a bad cell
tohoopty is offline
Old 06-13-2011, 06:51 AM
mjr46
mjr46's Avatar
unless you performed a load test and or checked the specific gravity of each individual cell you cannot state such.......there is more to testing batteries then just voltage being present so I doubt you performed or have the proper equipment to test batteries to draw a proper conclusion to what was bad about the battery.
mjr46 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
jpplaw
08-22-2015 09:29 PM
drumhedd2005
08-13-2015 09:59 AM
yurizx6r
08-11-2015 07:50 AM
89blueslug
08-10-2015 07:20 AM
Quick Reply: 89gt All good until I turn the Key?
