rearend noise after sus install
Old 06-10-2011, 05:16 PM
chevykilla93
chevykilla93's Avatar
Default rearend noise after sus install
So I finished up install a complete team z rear suspension kit with relocated uppers and now I am hearing a noise almost like a tire rub or tight brake that I didnt hear before. Have ruled out both of those as being the issue and set the pinion angle to -1 1/2. No recent gear change. Any ideas on what it could be?
chevykilla93 is offline
Old 06-10-2011, 05:18 PM
tohoopty
tohoopty's Avatar
when do you hear this noise
tohoopty is offline
Old 06-11-2011, 11:17 PM
chevykilla93
From starting out all the way to coming to a complete stop. I can hear it rolling in neutral and it seems to get louder the faster I go except in fourth gear at a low rpm I cant really hear it. It also amplifies when I turn side to side as well as hit the brakes a little hard.
Old 06-12-2011, 05:41 AM
AdderMk2
Banned
AdderMk2's Avatar
changing from rubber bushings to solid bushings will increase NVH. As long as nothing is actually rubbing, you shouldn't have any problems.
AdderMk2 is offline
Old 06-12-2011, 11:46 PM
chevykilla93
Whats NVH stand for? I have heard that switching to solid bushings can bring out a harmonic that was covered by the stock rubber but to me that means there is still an underlying problem somewhere.
Old 06-13-2011, 03:37 AM
AdderMk2
Banned
AdderMk2's Avatar
Noise, Vibration, Harshness
AdderMk2 is offline
mtgldr
02-03-2024 09:00 PM
bjdutch2005
03-24-2017 03:38 AM
robjh22
Suspension
09-08-2015 12:47 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: rearend noise after sus install
