Little cooling issue
So driving under these hot summer days i've noticed that cruising on the highway is making my temp creep. I have 2row radiator a ford contour fan 180 t-stat
The faster I go the higher the temp goes at 60mph I'm at 205. I know this isn't really that hot but if I were to go faster it would creep more.
As soon as I stop at a light the temp starts to drop. The car can idle all day at 185 even if I rev it.
Water pump??? Any ideas thanks
Yeah? Perfect condition motor, sure. Have you checked to see that your fan motors spin @ the designed RPM?
Have you taken your T-stat out and tested it in water on the stove, to make sure it opens completely, and quickly, at 180*?
You're assuming that all these parts you put in are working 100%. Any one of them working at 50% will cause your issue.
Think about it. You described your problem as a "slow overheat while on the throttle, perfect temp while idling".
This shows that something in the system is not working up to par, and it will take diag of each piece to figure out whats going on. You are creating less heat while idling, thus the system can keep up. While driving, the system slowly loses its effectiveness, and you gradually overheat.
Slow thermostat, plugged radiator/heater core, collapsed hose, slow fans... the list goes on. Even a bad coolant mixture can cause this. Too much antifreeze, not enough water.
