smog removal and ac removal
if i were to remove both the thermactor and the ac whet size belt would i need, is it possible to do this with moving the other assessories around as is required with the ac delete kit from ford racing, i would just like to strip the smog pump and ac out and place on a new serpentine belt if its possible, advice and suggestions would be greatly appreciated, thanks
RE: smog removal and ac removal
Im not sure about that much HP but you will pick some up because you have less drag on the motor. You will also save some weight off your front end. You can just take the smog stuff off completly but you will need some kind of plate or plug because the smog hooks up right at the back of your block and you will need to close it up. I just took mine off along w/ my ac but Im not sure what Im going to do yet either about a belt. Im sure if you go to one of your local auto shops they should have something that will work with your setup. It shouldnt be that hard.
jwog666
12-27-2021 08:09 PM
