hard pedal, RR brake dust abs light 95 GT
Old 07-11-2011, 09:33 AM
88GTBLACK
88GTBLACK's Avatar
Default hard pedal, RR brake dust abs light 95 GT
When you want to make a quick stop whether its 50 or 30 the pedal is rock hard and car doesnt want to stop.
Intermitent abs light.
3.73 install, both rear abs sensors were busted.
Before gears, right rear wheel wheel always got covered in brake dust as if it was dragging. but its not. Both rear calipers are brand new. and spin free.
Is this issue brake booster related? blockage in a hose? abs issue causing this? there are no vacuum leaks.
My girl needs good brakes, shes had a throttle welded to the floor board for 2 years since its her first RWD car and this brake issue combined driiving like I do, its time to have fun.
88GTBLACK is offline
Old 07-11-2011, 11:39 AM
Bubba 95SN
Bubba 95SN's Avatar
Check for vacum to booster. Got vacum? RR booster.
Bubba 95SN is offline
Old 07-11-2011, 06:07 PM
88GTBLACK
88GTBLACK's Avatar
There is vacuum. Enough to make idle jump way high I usually seefoam thru there. Eyeballed on a lift didn't see any pinches I'm stumped
Old 07-11-2011, 11:08 PM
AdderMk2
Banned
AdderMk2's Avatar
If you ave vac at the booster, and your pedal stays rock hard... replace the booster.
AdderMk2 is offline
Old 07-13-2011, 04:56 PM
Bubba 95SN
Bubba 95SN's Avatar
RR booster....Remove Replace booster
Old 08-04-2011, 03:56 PM
88GTBLACK
88GTBLACK's Avatar
bringing back my thread, I don't see how the booster would cause the RR wheel to do all the braking. RR wheel is dusty as ****. Its a new caliper from autozone so the pads it came loaded with are probably junk causing dust. but its a lot of dust. my wheel goes black in a week. yet on a lift you can hit overdrive up in the air hit brakes stop the rear tires and idle in drive itll spin no prob. I can spin the wheels by hand too. Im stumped.
Old 08-05-2011, 02:34 AM
Bubba 95SN
Bubba 95SN's Avatar
Maybe you will read and understand ......pedal is hard because of a defective brake booster. One brake doing all the stopping, car would pull upon braking, lock up one tire, and spin like a top. Hope this makes it a bit more clear. Get new sensors for the rear brakes.
musnicki
09-23-2015 07:11 AM
whatsup62
09-03-2015 01:38 PM
cbird1177711
09-02-2015 04:12 PM
chain
08-17-2015 08:52 AM
Quick Reply: hard pedal, RR brake dust abs light 95 GT
