Looking for some T5 info
http://www.allfordmustangs.com/forum...procedure.html
So 3rd gear is a weak point? Why?
I dont plan any hard launches, since its going in my DD I need it last as long as possible.
Are there any 3rd gear upgrades available?
Thanks
You can upgrade the entire tranny, Geforce and another company make gears etc.. for them.
As long as the engine is making under 250hp or so you'll be fine. I would highly recommend rebuilding it while its out and adding a aftermarket shifter to limit overtravel when shifting hard.
Now, assuming you get this all done. Bang the gears to your hearts content ***except*** third. When it come to third MAKE SURE its in gear before you release the clutch. I've personally ruined a T5 (in a 94GT) by trying to bang third as quickly as I did the 1-2 shift.
I've made over 200 passes down a drag strip in a 5.0L w/T5. They are tough enough to do the job. Just be respectful of 3rd and it'll hold up.
Regards,
Rich
Regards,
Rich
I have contacted G-Force, they have some quality parts. Huge gears to. I got in touch with them, a bit pricey but I think its worth it in the long run.
Regards,
Rich
Regards,
Rich
For now, its going to stay stock. I cant say the bolt-ons I add will increase the power that much where I have to worry about it.
Thanks for the explanation about 3rd. Gatcha.
Thanks guys, I appreciate the info.
Now, I just need to convince the wife. She doesnt now how to drive a car with a manual tranny. She's concerned if anything happens to our other car that she wont be able to drive the Mustang in case of an emergency. Thats a nice chunk o **** in the spokes. I need to convince her.
Thats true and a good idea. I wish I could find one for $80, if so, I'd build one instead of buy one.
If I do find one that cheap, I will buy it for a spare.
I had talked with a couple of people, one is an original/current owner of of 2 and another works for one of the venders. Both had said they are decent trannies. Just be carefull of 3rd gear. Make sure you're in gear before you let off of the clutch. Especially when driving more aggresive. I think the T5 will be fine, I wont be making any real power any time soon, so, it will do.
As for convinsing my wife. I dont think its going to take to much convinsing, hah.
about 300 LESS than an AOD
they arent what people make them out to be. 5k launches is what hurts them as long as it was built right...a crap rebuild might not last, but is still better than a AOD
3500 rpm launches on cheater slicks and you should be good til you break into the 11's
imo you'll break an axle b4 a t5, but ive broken a couple t5's, good thing is they are cheap and easy to fix
ive owned 3 5 speed 5.0's and 2 aod's
all else equal....in a t5 car.....you'll think you added 100 hp to it
read this.... http://www.westcoastmustangs.com/art...ap/t5swap.html
the swap is pretty easy (ive never done it) and not that expensive really. especially if you compare how much you'd spend to get into the new et bracket that you'll be in after the swap.
my slowest 5 speed was way faster than my fastest aod, hands down
