95 gt wont run
95 gt wont run
Hey i need help have a 95 gt I just did a auto to t-5 swap and put in a 255 fuel pump now it wont run. started up and then ran rough then it quit, now it turns over but wont start. has fuel at rail, could it be the computer?
yes changed ecm and harness, I dont know ran fine before swap. Got the whole kit from mps auto, its like the computers not working. It will start if i disconnect the fuel pump the die when out of fuel, then plug it back in and will start the idle low and die? Also i pluged in the auto computer i took out snd it will start and run, but idles rough and doesn't seem to run smooth when i give it gas. Also I can start it in gear or with the clutch disengaged, could it be a bad sensor causing this? Th ecomputer they gave me is a T4MO is this right all tranny parts are out of a 94-95 gt
