No turn signals or hazards
I suddenly have no turn signals or hazards and all my fuzes are good. This problem started after having a loose ground had a little bit of a short found the problem and now have no turn signals or hazards. I am just looking for ideas of what i can look into now. Any suggestions???
ok so played around with it after not being able to find the flasher relay and noticed a couple wierd things. First off if i hit my hazards or turn signals nothing would turn on. Then i turned on the lights and had the hazards on and it then showed my left turn signal staying constant. Also noticed the driver side head light is really dim. Then decided to turn on the brights with the hazards on then all the sudden the hazards started working. the right turn signal does nothing but if i turn on left turn signal it cuts them all out. i can turn the brights off and the hazards will still blink until i use the left turn signal. Also the rear turn signals are blinking good but the front ones are blinking oposite of each other and the driver side headlight is blinking with the ds turn signal.. this is driving me crazy any more idea please.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
