valvecovers for 1.7 rockers
RE: valvecovers for 1.7 rockers
If I remove the baffle then alot of oil will rise into the small oil line going into the intake. And I don't want to put a hose pointing to the ground so that the oil will drip on the road. If you have more ideas I'm listening.
Vfast you stole my valve covers
it depends on the 1.7s you run with stock covers. different RRs wont always clear stock modified covers. also with a spacer you will run into hood clearance issues and on a sn95 your tight already
ORIGINAL: 3stangs
will a breather get clogged and wet with oil. Also with 87 stock covers [ modified] will I still need a spacer on the intake
69MustangCoupe393cid
10-03-2015 10:33 AM
