Next addition to the car...
Old 09-09-2005, 01:19 AM
  #31
w8less
w8less's Avatar
Default RE: Next addition to the car...
well i bought used gears had them professionally installed and they Whine like CRAZY its so annoying i recommend buying new gears cause believe me the whining will drive u mad. i am saving up for new gears and then i have to dish out another 200 some odd dollars to have done all over again.
w8less is offline
Old 09-09-2005, 01:34 AM
  #32
92hatchLX
92hatchLX's Avatar
I'm not getting used gears, they are new.
92hatchLX is offline
Old 09-09-2005, 01:59 AM
  #33
Quik
Quik's Avatar
see not all pros know what they are doing. and just cause someone is paid t odo something doesnt make them a pro
if gears are installed right they wont have much wear or none at all
its half assing something when you dont replace things that should be. its like getting new rotors but using old pads, like adding new springs but keeping stock shocks.
also with gears there is sometimes adjustments that need to be made for the pinnon. if you over tighten that pinnion the rear will fail. also the rear pinion has a crush sleave which should be replace any time its unloaded. should i go on? do it right the first time. you can rebuilt the traction lok and not have to worry bout the bearings but since you are doing gears you should do new bearings
Quik is offline
b8checker
10-08-2015 12:55 PM
Florida Regional Chapter
09-30-2015 08:04 PM
b8checker
09-30-2015 07:11 AM
2015Ecoboost
09-17-2015 01:48 PM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: Next addition to the car...
