1993 gt second gear grind
hello to all, i just bought a 1993 mustang gt vert and i had a question. i pick it up tomorrow and when you shift it into second, sometimes it grainds. it is a 5 speed. i think i need a syncro. where can i get one and how hard is it to install? thanks to all..
Most part stores can get you a rebuild kit. And as mjr said most manual transmissions are pretty simple to rebuild, there should be plenty of guides to help you if you do a little searching and then you'll know its all fresh
thanks to all for the help... i called gearbox on thursday and saturday i had the parts.. i worked on getting the trans out today with not much luck... the guy who i bought it from put spot welds all over the exhaust, no cats and the smog pump is not hooked up. infact there is asmall pipe coming off the new exhaust where the smog pump is suppossed to hook in but he welded it closed... i tryed for over a hour to take off one nut that holds the header to the exhaust... still did not get.... will i be able to get the trans out with the exhaust still on... also what should i do about the smog pump.. i am going to put cats on... do i need the smog pump to pass inspection? thanks to all!
hello to all.. well i got the trans out with the exhaust on... it was a pain... i took off the exhaust at the headers so it could hang down... i want the car to be legal so i am going to hook up the smog pump and get new cats... the exhaust on there is 3" flowmaster so i will have to do some research... are there o2 sensors before and after the cats or just before? i have only one set now... i do have set of headers from a 91 mustang that i may put on.. i dont know what kind they are....
