climiate control problems!!!
ok i took a look at it and the vacuum wasent bad but when i pushed on the controls closer to the unit and the lever moved but it still didnt change the air movement from the floor, i also looked at the lines and they looked good, there grouped together but doesnt look like they r grounding out. do you think it could be the unit itself and not the wires?
ok when i looked at the controls and put pressure on it i could move the lever but it would only stay in floor mode. when i put it back on and everything the lever would only move from floor to windsheild and still only stayed on floor. it will not move anywhere else and when you put it to the windsheild the motor turns off.
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
