New 5.0 problems looking for solutions
Old 10-16-2011, 01:51 AM
gburge
gburge's Avatar
Post New 5.0 problems looking for solutions
hey I recently purchased a 88 5.0 mustang the previous owner put in a new motor with b 303 cam. the engine does not have a (maf) wondering if i can get any maf to fix my idle problem (chokes out/stalls) im having to manually ajust idle with my foot! i also own a 93 2.3 mustang wondering if i can take the parts off of it ie maf ? any suggestions?
gburge is offline
Old 10-16-2011, 09:09 AM
Timspony
SVT Section Moderator
Timspony's Avatar
Welcome to MF! ....1988 was the last year of Speed Density (except CA 5.0's) ... The MAF will correct the problem!!
You will need a MAF kit from a 5.0 set-up....They also sell these conversion kits with include the MAF, Wire harness & computer (A9L for a 5 speed)
Timspony is offline
Old 10-16-2011, 09:24 AM
Templar
Templar's Avatar
Welcome
Templar is offline
Old 10-16-2011, 11:36 PM
2005Redfire6
2005Redfire6's Avatar
Welcome to the forum!
2005Redfire6 is offline
Old 10-17-2011, 09:21 AM
CamOnlyWS6
CamOnlyWS6's Avatar
Welcome, yes a MAF Sensor should fix your issues, also if the car has an aftermarker cam expect it to have issues at idle unless you get the car tuned then you should be good to go!
CamOnlyWS6 is offline
Old 10-17-2011, 06:01 PM
gburge
gburge's Avatar
Thanks cant wait to start working on it over the winter.
gburge is offline
Old 02-04-2012, 04:44 AM
gburge
gburge's Avatar
Default still not running
I recently put in a bbk maf delete. Essentially removes the maf sensor out of the intake. (As seen in my album). I replaced all the spark plugs.(warn out and loose) to try and fix back firing issue. The car starts fine but the after turning over dies. Sounds likes its gasping for air. I tap the peddle to keep it from stalling. Yet for some reason have no control over the throttle it will shoot up to 3000rpm even with the smallest touch of the peddle.. With my cold air, aluminium racing headers and 303 cam i should be flying down the streets .. yet its stuck outside. i will take any suggestions into consideration so i can put my baby back on the road
thx.
gburge is offline
Old 02-04-2012, 05:06 AM
AdderMk2
Banned
AdderMk2's Avatar
you need t install a full maf CONVERSION... your car isnt going to run right without it.
You also probably have a large vac leak, and your timing is likely to be completely incorrect.
AdderMk2 is offline
Old 02-04-2012, 08:10 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
listen to addermk2
mjr46 is offline
Old 02-04-2012, 09:44 AM
89StangGTConvertible
89StangGTConvertible's Avatar
Welcome to MF! You will find that most of the members here are very knowledgeable, and helpful. Add a pic of your '88 Stang to your "garage", so we can check her out!
89StangGTConvertible is offline
Quick Reply: New 5.0 problems looking for solutions
