EGR delete
Old 09-11-2005, 11:22 PM
92hatchLX
92hatchLX's Avatar
Default RE: EGR delete
So quik are you saying not to delete it right now? With out underdrives isn't it like a 89.5 inch belt? I'm going to NAPA tomorrow so I guess I'll pick up a shorter belt and go ahead and bypass my smog, will it hurt anything if I just leave everything connected and just bypass the pump with a shorter belt?
92hatchLX is offline
Old 09-12-2005, 12:45 AM
NegadivOne
NegadivOne's Avatar
I ran mine with only the pump bypassed with a shorter belt for a few months and it was fine. Mine took an 84" belt.
NegadivOne is offline
Old 09-12-2005, 08:45 AM
Quik
Quik's Avatar
im saying and so is vfast dont bypass it. its really not worth it. you dont gain that much from it and its safer for the motor if you leave it on there. when you elimnate everything that is smog relate then its time to remove the pump. but what do i know
Quik is offline
Old 09-12-2005, 12:39 PM
92hatchLX
92hatchLX's Avatar
Nooo, I was questioning your knowledge I was just trying to get something straight .
Old 09-12-2005, 06:58 PM
vfast
I ♥ Acer
vfast's Avatar
yep...................also alot of time if the smog pump isn;t used for awhile is will sieze up
vfast is offline
Old 09-12-2005, 07:18 PM
Quik
Quik's Avatar
bypass is for track only. just liek a cheap mod is no belt at tyhe track also
Quik is offline
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
Camster
09-10-2015 11:18 AM
Quick Reply: EGR delete
