View Poll Results: A poll
Voters: 11. You may not vote on this poll
supercharger or top half kit?
i am looking at doing a big bolt on to my 88 lx, i want your opinions on which you think i should do first. The kb sc will produce liike 108 hp over stock, the trickflow (as tested on a 306 flattop piston motor with 9.5 to 1 comp. , 70mm tb, 190 fuel pump, mass air, and a 10* base timing) top half made 360 hp
RE: supercharger or top half kit?
what are your prices to compare????
and if prices don't matter, then obviously do whichever makes more power!!! i'd build the engine before adding a poweradder tho. that's my outlook.
the prices are a kenne bell sc for $3400 and the trickflow top end for $2200 the kb sc will give 108 hp, the trick flow top end will give a 306 flat top motor as described 360 hp, and yes i plan on hci and the bottom of the motor too, possible new short block with the $$$$ saved on going with the trick flow top end
ernesto-619
09-10-2015 01:32 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-03-2015 07:14 PM
