rear ends!
Old 09-13-2005, 12:54 AM
92hatchLX
92hatchLX's Avatar
Default rear ends!
Can someone list the rear ends that will fit the 87-93 5.0s? I found a BUNCH of 8.8 rear ends from broncos (early 80s) and explorers (non v8s) and trucks, but I'm just not sure if the non v8 explorer rear ends were 8.8s or not. Also where does it say on the differential what the gear ratios and stuff are? Thanks for the help!
92hatchLX is offline
Old 09-13-2005, 01:28 AM
Quik
Quik's Avatar
Default RE: rear ends!
tag on one of hte bolts say the gearing
any 8.8 carrier will work in the housing its just a matter of which axles you need ot use
Quik is offline
Old 09-13-2005, 01:25 PM
vfast
I ♥ Acer
vfast's Avatar
as trucks and such has 31 spline axles all I did is use the spider gears out of a truck and my 31 spline axle and good to go
vfast is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: rear ends!
