opinion on springs...what you using?
i'm looking for a set of lowering springs that wont hurt me at the track. right now i run the stock springs and they perform good.......good front end lift on launch. what's everyone using...what improvements?????
thanks in advance.
thanks in advance.
RE: opinion on springs...what you using?
I had an 89 gt that I cut one coil off the top of the stock coil springs. With a set of lake wood upper and lower control arms, leaveing at 4200 rpm dumping the clutch I was pullung 1.69 sixty footers.......Not bad for a bone stock block and heads with bolt-ons.But I never cut the front to match ride height so it sat down a little in the back.
ORIGINAL: HATCHEDIN87
Does any one use motorsport C springs?
ORIGINAL: caprirs_5.0
thanks in advance.
thanks in advance.
It seems like you're talking about two different things. Lowering springs ususally have a higher spring rate to make car stiffer. Car will handle turns better because of stiffness. Track cars like softer springs in front and harder in rear for weight transfer. They have 90/10 springs for front and 50/50 springs for rear. Drag springs do not not handle as well on the street.
[/quote]
i understand what you're saying...but i was just wondering if there is any springs out there that will perform like drag springs while also lowering the car. or if there are any tricks to accomplish this.
90/10s are struts, 50/50s are shocks not springs.
ORIGINAL: 95whitecobra
thanks in advance.
thanks in advance.
