Rear wheels not turning in neutral after brake change
I believe the term for the rotors you were looking for was vented, not slotted. Did the regular 95's have vented rotors? If not... maybe your pads were meant for the cars with vented rotors. Once again I'm not sure on sn-95 specs. Just a thought.
Front pads are different between GT and Cobra, rear pads are identical between them.
If the caliper had to be "pounded" back on, as stated, that should've been the first clue something was wrong. My guess is the caliper was not fully compressed since the cap or bleeder were not loosened prior to compressing the caliper.
Secondly, go to rock auto . com and look up the parts you got from the auto parts store. Make sure they are the correct part number (or post it here). I doubt that is the issue or your would've had the same problem on the other side.
Remove the rear wheel on the side that is giving you problems, remove the caliper, remove the pads, pop the cap off the master cylinder and make certain the caliper piston is pushed all the way in. The caliper with the new pads should just slide over without any force necessary.
I suggest you take your car to a brake repair place, and have them check it out for you. Tell them you want a brake inspection, no work done. They will tell you what is wrong. Then you can decide to either fix it yourself, or have them repair it. Sounds like the brake repair by hubby was not done properly. Old cars and newer cars have slightly different procedures for brake repair. Check an on-line parts supply that carries the brake pads you already installed, to make sure you got the right P/N. Then have them pull their pads, and compare them against your new pads. Sometimes pads are returned, and are not put into the correct box.
Both of the calipers had to be forcefully put on.. one more than the other. The pistons were pushed all the way in.. I watched him as he has me hold the caliper while he uses the weird cube tool to push the piston back in. It wouldn't ever hurt to try again though. I'll post the parts bought in a little bit.. I'll take a look myself later this evening to see if the caliper pistons are pushed all the way in.
Double check the part number then. I double checked with Ford's own website and the Rear are different between a Cobra and GT.
Aftermarket says they are the same yet the loaded calipers are different.
I've run into this before where all of aftermarket says one thing but the OEM is different.
I checked a 94 Cobra with the OEM and it is identical to the 95. I also checked aftermarket and the 94 Cobra part number is different than the GT as expected from what the OEM says.
Take the pads back to the auto parts store and have them look up rear pads for a 94 Cobra.
Guarantee that will fix your problem.
Sources:
santanford . c o m parts lookup, for OEM
rockauto . com parts lookup for aftermarket
Sources:
Come to think of it, I don't think that he tried pushing the piston done after I opened the brake cap.. I will do that tonight. It's got to be some type of mistake, I'm sure.
