Rear wheels not turning in neutral after brake change
Old 03-21-2012, 05:48 PM
  #21
brittny881
brittny881's Avatar
Previous owner put solid rotors on there.
brittny881 is offline
Old 03-21-2012, 05:58 PM
  #22
AdderMk2
Banned
AdderMk2's Avatar
then a wise move would be to check the thickness of them with a micrometer.
AdderMk2 is offline
Old 03-21-2012, 06:01 PM
  #23
brittny881
brittny881's Avatar
Around a 0.71 if I can remember right. I'll be back in there tonight, so I'll double check.
Old 03-21-2012, 06:26 PM
  #24
mattdel
mattdel's Avatar
Wow. Well my sources indicate that a plain 'ol GT rotor is 0.550 out of the box, with 0.50 as the minimal thickness. Take that for what you will, I really can't put together the pieces of this puzzle without being there.
mattdel is offline
Old 03-21-2012, 06:30 PM
  #25
AdderMk2
Banned
AdderMk2's Avatar
same. I dont have a micrometer to go check mine.
OP, you do know the difference between a vented and solid rotor.... right? We aren't talking about cross drilled and slotted.
AdderMk2 is offline
Old 03-21-2012, 06:34 PM
  #26
brittny881
brittny881's Avatar
Parts used are as follows from Advance:
Wearever Brake Rotor - Rear
Part No YH145035
Wearever Silver Brake Pads - Rear
Part No NAD 627
Old 03-21-2012, 06:36 PM
  #27
brittny881
brittny881's Avatar
I do have a micrometer to check, it's just not something I usually have to do..
Yes, I do know the difference.. this whole mess is exactly that.. I don't really care what has to be done. I just want my pony back on the road.
Old 03-21-2012, 06:41 PM
  #28
AdderMk2
Banned
AdderMk2's Avatar
problem is the pads. most part stores have the same listing for cobras and GT's
You can either get pads from the dealership, or sand them down slightly to make them thinner.
No way around it. Sorry.
AdderMk2 is offline
Old 03-21-2012, 06:42 PM
  #29
AdderMk2
Banned
AdderMk2's Avatar
could also try removing the shims.
AdderMk2 is offline
Old 03-21-2012, 06:46 PM
  #30
brittny881
brittny881's Avatar
Yeah I did a little looking into the size of the pads.. the silvers are .673 inches and the golds are listed as 14.9mm for some reason which is .58 inches.. so more than likely those need to be purchased.. it's super ridiculous the trouble just to hold a car over until the correct rotors get here.. Thanks for all of your help!
Quick Reply: Rear wheels not turning in neutral after brake change
