New brake calipers don't squeeze
hey all,
I am doing a t-bird reared swap and am at the point of bleeding the brakes. I got new calipers and a proportioning valve. I redid all the brake tubing from the master cylinder to the booster and all new from the rear banjo bolt to the calipers. I have no leaks and all lines are patent and I am getting fluid to the calipers. However, I am not getting fluid THROUGH the caliper on either side. As I said, they are both new calipers so I don't believe that is the problem. Does anyone know what might fix this? Do I need to unscrew the piston prior to installing? I am at a loss and could use any help I can get. Thanks in advance.
musnicki
09-23-2015 07:11 AM
09-02-2015 08:40 PM
