HELP PLEASE!!
[QUOTE=Tony71502;7892576]Bingo...that's it, forgot it's name, been so long since I fooled with one. But yeah I do know some people incorrectly read the stock timing because they forget to unplug this basic connector.
Hi all, I'm gtgenos friend that has been helping him through this. We have done so much work on this car it literally boggles In the back of my mind as I sleep. Fuel system is a go. We hooked up a fuel tester and did all appropriate tests 35+ lbs strong at idle and climbs to 40 without hesitation when driving. Fpr is good too. Timing was done by a mechanic he knew, that's the only thing i cant firsthand confirm, h replaced fuel filter, o2 sensors, cats, egr(a year ago) and I recently tuned his tps along with reset the iac. The only reason I rule out timing is there's no miss, and his major issue is only under load in drive and reverse, in neutral and park the car sometimes stumbles bit not as bad. If it were timing it would miss and die out no matter what. The car idles fine after initial start up. I rule out ignition due to same reason, it doesn't miss and only under load does it die out, just like a vac leak. System seems fine as far ad vac goes, havnt tested pressure. The best I've seen it run was last night when I unplugged the egr, It still hesitated a little but it started right up without being at wot, and barely stumbled when he backed in and out of his parking stall. All my guts point to egr issue. Any other ideas givin this info?
I would just like to say to everyone who took the time to try and help thank you. I took my car to the shop because I got tired of trying to fix it. It turns out my problem was a fried ECT (Electronic Coolant Temperature) sensor. The car had no idea whether it was warm or cold. It also caused my ECU to get really confused as it started dumping fuel through the injectors. Also when I adjusted my timing the info I received was to set it at between 8*-12* atdc. Well that info was backwards. The shop set my timing at 10* btdc and the car has never ran better!
