Plugs and wires
RE: Plugs and wires
What do you have done to the engine? If you have some performance parts i used the Autolite Racing Plugs from Advance Auto Parts part Number AR25 and if you have the money i went with MSD wires.
RE: Plugs and wires
Thanks for the input, I think I will go with the autolites. I just purchased the car and there are some mods. BBK 70mm TB,
headers, BBK cold air kit, cobra intake, cam, Crane cams fireball ign box and I was told it has some heads off a 5.0 explorer on it. What would these heads bring me in added perfofmance? I pulled one of the plugs that it had in it and it was a single platinum motorcraft. The plug was a dry and black and you could wipe off the black deposit. Is my car running rich? It hasn't been running worth a _ _ _ t ! I just replaced the TFI and a least it quit popping. Now I just need to set the timing. But before I do that I want to replace a few things and a tune up.
This is a great place and I glad I found it!
Thanks for all you help,
Roger
Roger
RE: Plugs and wires
Personally, I've bought the Performance Distributors' Firepower Package Ignition Kit. You get the 10mm wires, rotor, cap, dyna-mod as well as the coil. I bought NGK Iridium plugs with this kit and let me tell you, it runs great Good luck with the car
www.performancedistributors.com
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
