89 stang wont start need ideas - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 03-29-2012, 04:57 PM
GTnotchback
GTnotchback's Avatar
Default 89 stang wont start need ideas
Working on an original 87 4 cyl car that now has a 89 5.0 mustang engine and everything. Long story short it ran very well and was put away and stored over winter outside i believe. Sat all winter and now will not start. It just turns over and over and never tries to fire. Looks like it is getting fuel and i can hear the pump run. Just put a new i think its called TPI on the front of the distributer but it didnt help. any ideas to try?
GTnotchback is offline
Old 03-29-2012, 05:17 PM
jthorn9
The Godfather
jthorn9's Avatar
Stupid question but you didn't unplug the fuel relay did you?
jthorn9 is offline
Old 03-29-2012, 05:38 PM
GTnotchback
nope. then the pump wouldnt run right?
Old 03-29-2012, 06:06 PM
ponyracer50
you dont mention that you checked spark. check that. simple things to run are power, fuel, spark and then compression. I had a 5.0 sit for a winter and it lost the ring seal so no compression.
ponyracer50 is offline
Old 03-29-2012, 06:59 PM
GTnotchback
o guys heres the latest i have found. Turn key to on and the fuel pump runs constant. Turn key to start and pump shuts off and engine rolls with no fire.
Also it only gets spark on the plug once i let off the key from start position and let it flick back to the on position. what the heck is goin on!? bad ignition where the key goes in?
Old 03-29-2012, 08:36 PM
mattdel
mattdel's Avatar
Possibly, but more likely the electrical ignition switch that is bolted (riveted?) to the steering column under the shrouds. Either way check both for obvious signs like melting or frayed wiring, and if none seem apparent, replace the electrical switch first.
mattdel is offline
Old 03-29-2012, 09:13 PM
GTnotchback
anyone know where i can get one? or how to do it?
Old 03-29-2012, 10:07 PM
mattdel
mattdel's Avatar
mattdel is offline
Old 03-30-2012, 06:12 AM
GTnotchback
wow thanks alot youve done it all but put it in for me!
Old 03-30-2012, 10:58 AM
GTnotchback
well dang. i talked to the owner and he said he already replaced the ignition switch. now what im running out of things here other than bad wiring harness
Quick Reply: 89 stang wont start need ideas
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
