oil consumption
oil consumption
Hello, I am fairly new to the mustang world. I just got a 1992 Mustang LX 5.0 It is in great condition. I have an issue with my oil being consumed. I am almost positive that its being burned but I dont see any blue smoke. there is never any oil on the ground. I dont know what more information I need to give to you, just ask and I will tell. Thanks for the help!!!
RE: oil consumption
A lot of high mileage 5.0s burn oil. My car has 138k and it seems to burn around a quart a month. Its not usually a huge deal, as long as you watch it and add oil occassionally the motor could last much longer. A guy I know from New Jersey bought a 5.0 with 140k that burned oil, and it still runs great at 165k.
RE: oil consumption
its probably your rear main seal has gone bad bc your not burning oil and the rear seal is a weak point from the factory bc its a 2 peice seal. I would jack up the car and try to see if there is oil in your bellhousing if so replace the rear main seal with a fel-pro 1 peice rubber gasket
