93 mustang not starting
Old 05-04-2012, 10:33 PM
mustangGT86_05
mustangGT86_05's Avatar
Ok a few tips here, there is no wire for a ground off the starter, they ground through the body of the starter through the engine so it is possible dirt/oil grime created too much resistance. Also, it is possible your starter is bad, when you were tinkering around on it you might have jarred it enough to get it started so don't be surprised if the problem returns. If it does, take a hammer and tap the case lightly, if it starts you should replace the starter. What I suggest right now is remove the starter and clean it and the part of the engine it mounts at, brake cleaner will do the trick
mustangGT86_05 is offline
Old 05-06-2012, 10:26 PM
1fast Lorinser
I personally used a 4 gauge wire from my starter bolt straight to my negative terminal on my battery. All is well now
1fast Lorinser is offline
ShaneB26154
34
05-15-2016 09:30 AM
Urambo Tauro
09-07-2015 12:47 PM
KEM Motorworks
08-14-2015 10:13 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 93 mustang not starting
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
