MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   5.0L (1979-1995) Mustang (https://mustangforums.com/forum/5-0l-1979-1995-mustang-14/)
-   -   What size injectors do I need? (https://mustangforums.com/forum/5-0l-1979-1995-mustang/670655-what-size-injectors-do-i-need.html)
fordmustang945.0 04-25-2012 02:32 AM
I just purchased a 94 gt with the following work done to the engine:
-Trickflow upper and lower intake
-Edelbrock Performer heads
-Crower 15511 cam
-1.6 roller rockers
-Hooker shorty headers
-MAC catback exhaust
-MAC CAI
-65mm throttlebody
-190lph fuel pump
The previous owner did all the work to the car. It is using 24lb injectors right now and a bbk adjustable fpr running at 42psi. I think this seems like a little much and I have a set of 19lb injectors sitting around. I just don't want to put them on and run the risk of leaning out the engine. Does it need the 24's or would I be fine putting the 19's in? I really don't want to spend the money on an AEM UEGO to tune it once and then not use the wideband again.
Thanks
mjr46 04-25-2012 06:41 AM
24's are fine leave it alone
BaltRavens 04-25-2012 02:05 PM
#24 be all you would need.
nitrous_bob 04-25-2012 08:55 PM
42 psi vac off ???? your perfect
Venomantidote95 04-27-2012 01:43 PM
Yes you are good to go dont change a thing but plugs and oil lol, until the time comes to go bigger all around!
ttocs 04-27-2012 04:30 PM
will a 190lph pump feed 24s in high rpms?
Delia38 04-27-2012 07:14 PM
http://www.heritems.info/avatar2.jpg#24 be all you would need.
Venomantidote95 04-28-2012 10:49 AM
yes a 190 will be fine with any rpm one 24`s as long as you have a good working regulator.
