a/c delete
RE: a/c delete
I left my power steering where it was and used a 82.5' belt
you just have to be creative with the routing.
heres how I routed mine.
[IMG]local://upfiles/13948/E2576854235D43528AB2E97B8CC7A405.jpg[/IMG]
RE: a/c delete
the only drawback is with underdrive pulleys, to put the belt on, you need to take out the lower power steering bolt and rotate it in a little then pry up the tensioner and put the belt on the alternator. then to put the bolt back in you need to pry on the tensioner( I use a pry bar and hold it with my head) and pry on the power steering pump while trying to get the darn bolt back in.
good luck
good luck
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
