SN95 Alt wiring diagram
Pretty simple. The way I did it (if my memory serves me correct), cut of fox plug that has the two blk/org wires and white wire. The blk/orange wires are actually one wire. Find where they meet and take off the one spliced section. Put ring on the end. Put that and a 4ga cable onto the post on the alt. Run the 4ga to your solenoid (with a fuse). I'm pretty sure the other wire that was on the plug got a female blade connector and plugged into the alt. Then you have the D shaped plug, that one plugs right in. If you do a search there's a ton of information.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
