'89 GT Upper Intake Leak - Pics (HELP!) - MustangForums.com
Old 04-28-2012, 08:21 PM   #1
kowalczyk86
Default '89 GT Upper Intake Leak - Pics (HELP!)
Need some help. What is causing this leak? What all do I need to take apart to replace these gaskets that appear to be leaking (if they are not gaskets, what else is going on here)? I have 4 Mustang books (Haynes included), but cannot seem to figure out where I need to look. Nothing is helping too much.
Pics here http://stangplanet.com/forum/fox-bod...html#post27419
since this website wont let me upload any.
kowalczyk86 is offline   Reply With Quote
Old 04-28-2012, 10:38 PM   #2
mattdel
mattdel's Avatar
Replace the gaskets and thoroughly clean the PCV system while the intake is apart. Crankcase pressure makes oil seep anywhere & everywhere.
mattdel is offline   Reply With Quote
Old 04-29-2012, 02:24 PM   #3
Bubba 95SN
Do not fogdet the screen below the pcv, replace.
Bubba 95SN is offline   Reply With Quote
Old 04-29-2012, 08:11 PM   #4
kowalczyk86
How much work is involved in this? I have some manuals, so if you can give me a subject, I can look for a how-to. I don't see anything under "manifold".
I will say that I have had the following problem that I have yet to get rid of:
In the last year or so, my RPM has stuck at 2K idle for a minute or so. This has happened only twice I believe. It was pretty bad but went away.
When I am driving, and I throw the car in neutral and coast, the car will idle at 1,200 RPM or so for a bit and then finally drop to 900 or so. Not sure if this has anything to do with that residue. The car only has 24K original miles on it.
Old 04-29-2012, 08:12 PM   #5
kowalczyk86
Someone on another forum said,
Are you sure its leaking? When is the last time you cleaned that area off. Some purple power or simple green and a garden hose should get most of that residue off . Then if it comes back in a short time I would worry about leaks. There really is no oil of fuel flowing thru that part of the intake, if you have a leak you should see a problem with vacumm like the previous post states.
I am not positive that anything is leaking, but what is all that residue?
Old 04-29-2012, 10:18 PM   #6
mattdel
mattdel's Avatar
Mostly dust particles and dirt. What the residue actually is makes no difference. The fact that it's sticking to a gasket mating surface points to a bad gasket. The fact that it's an upper intake gasket points to PCV system.
Old 04-30-2012, 02:44 AM   #7
kowalczyk86
My Dad and I changed the PCV valve when we bought it only a couple years ago - would it be filled already?
Old 04-30-2012, 05:18 AM   #8
Foureyed
Foureyed's Avatar
The Air Control Valve maybe gummed up, take it out and spray some brake cleaner in it, that may just cure your idle problem.
Foureyed is offline   Reply With Quote
Old 04-30-2012, 11:48 AM   #9
kowalczyk86
Quote:
The IAC? If so, that was replaced.
Car died while driving... StalkerGT 5.0L (1979-1995) Mustang 13 09-25-2015 02:41 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 07:30 PM
Upgrading to handle slicks? Info needed Dragonus18 4.6L (1996-2004 Modular) Mustang 8 09-09-2015 01:21 AM
need a water pump step by step guide needhelpplease 2005-2014 Mustangs 7 09-04-2015 09:59 AM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 08:43 PM
50, 89, 95, changed, convertible, fuel, gt, intake, leaking, mustang, pictures, power, problem, removal, seeping, upper
Featured Sponsors
