need help on rear springs
Old 05-25-2012, 03:24 PM
85notch-foureye
85notch-foureye's Avatar
Default need help on rear springs
Hey MF I need help on my 85 mustang deciding if 4 cylinder stock rear springs are better or 96 gt stock ones im currently gonna install some KENNY brown super subs and sum MM HD lower control arms so before I install them I would like to hear ur opinion on what spring is best for the rear even if its not the two mentioned on top its mostly gonna see drag racing but also some street driving my front springs are pretty stiff hope this helps thanks MF
85notch-foureye is offline
Old 05-28-2012, 01:10 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
If you're changing your springs for a street strip setup, I'd recommend these springs:
http://www.uprproducts.com/mustang-e...pring-kit.html
Either of the springs you mentioned would work, but not as well as the springs I linked above. They are the best street-strip setup you can use, without going the full race route.
UPRSharad is offline
Old 05-29-2012, 02:25 AM
85notch-foureye
ill look into those thanks for the help uprsharad
Old 06-04-2012, 10:39 AM
UPRSharad
Former Sponsor
UPRSharad's Avatar
No problem. There are many different ways to go on the springs, but that is the simplest, most effective choice. We also have a pretty nice adjustable height spring kit which is GREAT for adjustability, but it requires some minor welding so it's not used as commonly as the spring kit I linked above.
Old 06-04-2012, 10:42 AM
JPJP
JPJP's Avatar
Eibach Drag Springs are great!
JPJP is offline
Gene K
10-21-2015 11:37 PM
09-16-2015 07:53 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: need help on rear springs
