What made my head gasket fail?
I had a hole between each cylinder on head gasket Rest of gasket looked fine car was sitting for two years and took it to shop to dyno tune and wonder if it was from sitting detonation on dyno or install failure gt40x heads with steeda 19 and kb charger with 11 psi used felpro 1011 gasket and arp head bolts torqued to 70 ft lbs with oil They said head bolts were loose on bad side when taken apart
Look at my mods listed in my pictures. NO leaks or head gasket issues. Spend the money and do it correct. To bad your studs were loose. Make sure your engine is warm before hitting it hard. A cold engine and a heavy foot can cause a head gasket to leak.
Studs don't stretch like standard head bolts do. (Yield to torque)
The last engine I built I wound up re-torquing the studs four days in a row before they would hold at 75ft lbs. After first day the highest I had was 55ft lbs and one was at 35ft lbs! (they were ARP & I was using their special lube)
Torque and retorque.... and retorque.
Luke9222
10-22-2015 11:55 PM
TfcCDR
09-14-2015 12:08 PM
