HELP NO SPARK
Old 04-25-2010, 12:54 AM
Frank567
Frank567's Avatar
Default HELP NO SPARK
Hi My Mustang has no spark right off the coil parts that have been replaced are a new ignition control module new coil and about 4 months ago when this last happened I replaced the hole distributor and it ran great but now its happening again
All fuses check out okay
there is power to both wires going to the coil but not sure if thats normal
the next thing I can think of would be the computer ?
if you know anything that can help me I would appreciate it
Its a 1994 5.0 5 speed
Frank567 is offline
Old 04-25-2010, 01:22 AM
nitrous_bob
nitrous_bob's Avatar
the module on the dizzy is a big culprit
nitrous_bob is offline
Old 04-25-2010, 02:55 AM
luckythirteen13
luckythirteen13's Avatar
did you go out to the car one morning and it wouldnt start? or was the car running, cut out, and wouldnt start back up?
luckythirteen13 is offline
Old 04-25-2010, 12:42 PM
Frank567
Frank567's Avatar
the module is new, on my car it was mounted under the airbox on the passenger side fender and it was running and then died out and then i checked for fuel pressure since i just put in a fuel pump but that was good and then i put on my spark tester and am getting nothing right off the coil but power to both sides of the coil.
Frank567 is offline
Old 04-25-2010, 02:54 PM
wadesquad
wadesquad's Avatar
use a 12v test light to ground to the wires goin into the coil and have sum1 trun the key see if your light flashes... if it does i would say your coil is shot... if it doesnt then your pick up in the disti. is shot... any of which are a $20 fix.
that is considering that all your fuses are good that is....
wadesquad is offline
Old 04-26-2010, 02:45 PM
Frank567
Frank567's Avatar
Ive replaced the coil and the pick up all within the past 6 months would they go bad that fast ? and do you have any idea why I am getting power on both wires going to the coil ? I dont think thats normal
Frank567 is offline
Old 04-26-2010, 04:31 PM
mattdel
mattdel's Avatar
No its not. trace them back, you're shorting to 12v somewhere.
mattdel is offline
Old 04-29-2010, 12:41 AM
Frank567
Frank567's Avatar
can you tell me what i should look for as i follow them like anything specific ? thanks
Frank567 is offline
Old 04-29-2010, 12:44 AM
gunpig0313
gunpig0313's Avatar
The TFI Module is on the dizzy not under the air box. They always go out it's like an 80 dollar part go buy a new one and hook it up like 10 mins of work.
gunpig0313 is offline
Old 04-29-2010, 01:14 AM
mattdel
mattdel's Avatar
he has a 94, its under the air box.
mattdel is offline
Quick Reply: HELP NO SPARK
