my a/c isnt working and its been over 100 outside!
1990 mustang gt.
my ac isn't working properly, it blows cold air and all but it comes out very low, even on high it still barley comes out. any idea where i could start looking for the problem? had the a/c recharged and was blowing super cold air last summer, but now im sweating my a$$ off coming home from work in the dang Ga Heat.
Given that it still barely works, I'd venture a guess and say you have a tiny leak, probably in an Oring connection or possibly the shrader valves on the hoses. Get a leak test/recharge, should be fine.
edit: ahh misread it. disregard and go down.
Are you sayin the fan isnt blowing except on low or that it isnt very cold?? If the fan is only blowing on low it could be a blower moter resister the blower moter itself or the switch is bad. If its not blowing very cold air you may have a problem with the blend door not closing the heat off all the way. I may be mistaken but usually when the blower moter resister block goes bad the moter will only work on high . You probly have a bad blower moter
1990 mustang gt.
Here with it being 110+ outside the best I could get my car to do was 58 degrees at idle and 50 running. Don't know about you but in a sealed up car with good quality tint, you should be fine, I don't sweat a lick in my car out in AZ.
