Steering rubbing feel/sound in hot weather
Old 07-10-2012, 07:45 PM
Canary94GT
Canary94GT's Avatar
Default Steering rubbing feel/sound in hot weather
I've been noticing a rubbing feel/sound when I turn my steering wheel on hot days. I noticed this last summer, and then it went away during winter, and now it has reappeared since the temperatures have warmed up recently.
It just feels a bit harder to turn the steering wheel and I can hear a rubbing-like noise as well as feel it.
Any ideas what would cause this?
Car is 94 GT with approximately 83,000 miles
Canary94GT is offline
Old 07-10-2012, 08:02 PM
mattdel
mattdel's Avatar
Hmm.. Can't say I've ever heard that one before. First off check tire pressures. Then... possibly the joints in the tie rods are drying out? IDK. Weird.
mattdel is offline
Old 07-10-2012, 08:15 PM
Canary94GT
Canary94GT's Avatar
Yeah, I was surprised I couldn't seem to find much about it in searches.
In my logic, it seems like something is either drying out or swelling up in the heat. When I had service done a few months ago, the mechanic said it could use a power steering flush, but I tend to ignore those things. Could that claim stand some ground though?
Old 07-10-2012, 09:06 PM
mattdel
mattdel's Avatar
Possibly. As with any hydraulic system, if the viscosity is lower than recommended, results are lower than expected. The increase in pressure required to turn because of thin fluid could cause a minor binding feeling.
mattdel is offline
Old 07-10-2012, 09:17 PM
dawson1112
dawson1112's Avatar
Does it do this as soon as you start it up and go or does it take a little while to heat up and then start? Also could you get a audio clip of the noise your hearing on here for us?
Power steering flush ? maybe but highly unlikely. Could be a partially plugged up line or power steering cooler. Maybe a little air in the system a slight cavitation can sound a bit like rubbing and make it a little harder to turn.
I ran into a pump pully one time that when it got hot out and the engine warmed up the pulley would slide out on the shaft a bit and slip a little when it was cold it would hold solid was odd but must have been worn just enough.
dawson1112 is offline
Old 07-10-2012, 09:36 PM
Canary94GT
Canary94GT's Avatar
It happens as soon as I start it up on these hot days. I might be able to get someone to turn the wheel for me and have me record it and/or listen to where it might be coming from. Otherwise, it's kind of quiet from inside the cabin. But it's not just the sound - I can definitely feel it when I turn the wheel.
I will take a look next time I get a chance.
Old 07-11-2012, 08:43 PM
Canary94GT
Canary94GT's Avatar
I checked the fluid level and it is within the "FULL COLD", "FULL HOT" marks.
However, the fluid level is black and smells strongly. Not sure if it's supposed to be like that.
Also, I tried to listen to the noise from the engine compartment, but I was unable to hear the rubbing sound over the engine. On the other hand, there are other noises coming from the pump, but not sure if they are normal or not.
I recorded a video while someone turned the wheel back and forth, but the engine makes the noise sort of hard to hear.
Old 07-11-2012, 08:59 PM
mattdel
mattdel's Avatar
normal ford whine. the black fluid, however, is a symptom of a dead rack.
mattdel is offline
Old 07-11-2012, 09:22 PM
Canary94GT
Canary94GT's Avatar
Blah, how much would that cost in labor to be replaced?
Old 07-11-2012, 10:07 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just flush the fluid, fluid gets dirty and burnt over time, doesn't always mean replace the rack, if steering assist is fine, flush and go
mjr46 is offline
Quick Reply: Steering rubbing feel/sound in hot weather
