Which Clutch Should I buy?
Old 09-22-2005, 10:26 PM
FoMoCo
FoMoCo's Avatar
Default Which Clutch Should I buy?
I am about to start modifying my 92' 5.0 5-speed but first I need to buy a clutch. There are alot of kits out there, but I want to buy the centerforce dual friction clutch kit. Can I use this clutch on my stock 5.0 until I get some serious horsepower? Or which clutch do you recommend?
Need your advice...
FoMoCo is offline
Old 09-22-2005, 11:07 PM
P.S.I.cho
P.S.I.cho's Avatar
Default RE: Which Clutch Should I buy?
right now on my 95 im just using the king cobra clutch kit with no problems, but my neighbor runs spec stage 2's and 3's in his mustangs and there a pretty serious clutch fo what ever you wanna do, u can get a light weight flywheel while ur at it, or if u dont want to spend the money make sure u atleast get your flywheel turned (napa, autozone, checkers, carquest) just about anywhere will do it
P.S.I.cho is offline
Old 09-23-2005, 05:42 AM
94ford5liter
94ford5liter's Avatar
moocow_v is your car a v6 or how did you only run a 16.1?
94ford5liter is offline
Old 09-23-2005, 07:11 PM
sc94gt
sc94gt's Avatar
The Spec Stage II grabs awesomely!
I took it to the track and it performed very well for me.
sc94gt is offline
Old 09-23-2005, 07:24 PM
Madskillz306
Madskillz306's Avatar
Your On the right track Man. Centerforce dual fricton all tha way.
I had King Corba in my stock engine and it lasted 3 years decent clutch, but changed engine to 306 about 310 ponys to the wheels and i went with a center force dual fricton, in fact afew buddys I know with 347 strokers pushing 400 ponys and other stang 500 ponys to the wheels are using this same clutch and they still working wicked even after afew seasons multiple track runs.
Go Centerforce dual fricton I did and it's a decent heavy duty clutch.
Madskillz306 is offline
Old 09-23-2005, 07:48 PM
TMC
TMC's Avatar
I agree too...
The best clucth out for a street/strip bolt on stang is the CF DF. They have the best pedal feel and hold enough power for 99% of the cars out there.
TMC is offline
Old 09-24-2005, 12:05 AM
posnick
posnick's Avatar
what he said^^^^^^ i was running 300 at the the wheels till i decided to rebuild and never had an issue with mine. its easy on the leg to
posnick is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
09-25-2015 06:30 PM
Quick Reply: Which Clutch Should I buy?
