How to Remove Flywheel?
No heat, replace flywheel bolts. +1 flywheel tool. Holes in crank go straight through crank. Look with flashlight..it is so.Therefor sealant must go on flywheel bolts or there is a oil leak. Replace rear main seal while there.
Luckily i haven't taken a torch to it yet. It seemed kinda sketch. So i won't be doing that.
I'll try to jam the flywheel teeth with something like suggested. If that doesn't work i think i'm gonna try to slip a second breaker bar on the crank bolt wrench and wedge it against the floor so it absolutely can't move and then try to loosen the flywheel.
I really wish i had an impact wrench. That's the next tool i'm getting for sure. It would have come in handy so many times.
Will report back shortly. Thanks
Thanks peeps
