Are replacement pullies good or bad?
I have heard alot of good and bad stuff about pullies. do they really give you the horses they say they do. Do pullies affect the charging and cooling systems? are they worth it? will they help?
by the way I have a '92 Mustang GT with
cobra intake
msd ignition
knn cold air
hurst shifter
bbk h-pipe/Flowmaster exhaust
3.55 gears
traction bars
cobra intake
msd ignition
knn cold air
hurst shifter
3.55 gears
traction bars
RE: Are replacement pullies good or bad?
Kinda sounds like my ride
About underdrive pullies. I think they do free up some HP, as everything is turning slower (waterpump, alternator, power steering, smog pump, AC). I don't think it frees up enough power that you can feel it by driving the car around town, but you might notice it at the track if you're a good and consistent driver.
The trade off is that at night, you will notice, with your lights on especially, that your alternator gauge will read lower than before. Does it hurt anything? Not that I'm aware of. But if you have a big fancy stereo system requiring plenty of amps, then I would not get underdrive pullies.
Put pullies on the vert and felt a difference, because the crank pulley is alot smaller the car gets up and goes faster without having to turn all the accessories over. Sure the lights dim at an idle but thats about it, car runs at about 190 degrees in 95+ florida weather. I bought the march set and am really pleased.
if you are worried about charging, you can just use the crank and water pump pulley with the stock alternator pulley. The alternator pulley seems to make the lights dim, but I haven't heard of any cooling probs associated with the water pump pulley.
Diode Dynamics
28
05-26-2022 12:02 PM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
