Pro-M 75mm + new 24lb injectors runs crappy?
So just got this 75mm Chrome MAF calibrated for 24lb injecors, got some rebuilt 24s both from ebay - i put it all together but now im running super weird like clogged or something..i did base idle reset, idles good but when i throw some revs it studders almost, inbetween 2k-3k rpms theres are clogg kind of feeling so i took all injectors an fuel rails apart to make sure a proper installation an tried again but same thing..any ideas??
do i have to change anything else/do anything else besides change maf an actual injectors? would a stock fpr work on 24lb injectors?
i put my adj fpr on for kicks to rule out pressure problem but maybe i didnt adjust it properly...i mean i set it to 39 with vacuum line off, with line on it goes down to like 26-30 more around 30 but even if i adjust it up or down it doesnt go past 40 wit vac line off or on...
another thing is when i bring the rpms to a steady 2k after about a minute maybe a little less without y foot moving a hair on the pedal my rpms drop to like 1.5k by itself im thinking something to do with throttle body?? i got a 65mmtb.. ????
Update : Kept 24lb injectors on but took off the maf, put old stock 19lb maf on and now got a lot of power better than with the 19 lb in..super happy finally got my performance! im sure it could run a bit better but since i put my heads on ive had trouble finding my torque/power but im happy for the time being - im guessing the maf i got was calibrated different somehow than what i need...it said it was a 75mm pro-m maf calibrated for 24lb injectors but just didnt work right maybe i can get it calibrated or something...wonder if i could get much more hp out of my setup if i run a proper MAF...Think the maf couldve been set up for a larger throttlebody? mines a 65mm ..?
FORD MUSTANG COBRA 87 - 93 24LB 24 LB FUEL INJECTORS is what the ebay listing was...they were fully rebuilt and are blue in color : ) im guessing the original owner of the maf had a larger throttle body? im stumped dunno what the heck...an hey mj it was u who said go pro-m! :P haha my luck uuhgg got the chrome 75mm pro-m calibrated for 24s in cold air fendermounted (which i have) for only 135 buckaroos not bad eh? if only it would work tho : (
so ur saying u think the 24s i got arent truely 24s? an thats y they work well with my stock maf an not well with the calibrated pro-m maf? they looked brand new not rebuilt so im guessin theyr knockoffs too...they were 100 bux on ebay...motor runs way better with them instead of the 19lbs i had but the old 19s i had were beat to crapp an old so maybe oh hell i dunno : (
isnt a tune needed when the maf & injectors are replaced? i dont think you can put those parts on without one. running the stock maf with the 24# isnt a good choice, it might be running better but i bet your air/fuel mixture is not good.
