Car stuck cranking
Old 08-19-2012, 10:24 PM
  #21
jst98gtmustang
jst98gtmustang's Avatar
i double check all everything to make sure it hook up right and it is..
jst98gtmustang is offline
Old 08-20-2012, 10:38 AM
  #22
mustangsneverdie
mustangsneverdie's Avatar
it sounds to me like you dont have the positive wire hooked up right or just loose, and then again it could just be that the battery is dead
mustangsneverdie is offline
Old 08-20-2012, 01:34 PM
  #23
mo_dingo
mo_dingo's Avatar
Is it still doing the same thing?
mo_dingo is offline
Old 08-20-2012, 02:09 PM
  #24
jst98gtmustang
I took this starter solenoid back again and just return it and went and got one from a ford dealer..i'm going to see tonight when i get home if that will take care of it.
Old 08-21-2012, 06:29 AM
  #25
oldfordisbetter
oldfordisbetter's Avatar
mine did that a few times.... was starter soloniod.. took me 4 tries to find one that worked right... ive got over 50 starts with it now and am happy. although now since replacing the last one now my radio dont work...fuse is good but radio wornt turn on...
oldfordisbetter is offline
Old 08-24-2012, 07:20 PM
  #26
jst98gtmustang
Well i put in a motorcraft soloniod from ford and it still doing the same thing.
Old 08-24-2012, 07:21 PM
  #27
jst98gtmustang
that the 3rd one.i am getting power now,just cranks after i turn key and will not stop..any other ideas?
Old 08-25-2012, 12:09 PM
  #28
jst98gtmustang
could it be the starter?
Old 08-25-2012, 01:36 PM
  #29
mattdel
mattdel's Avatar
Stop guessing and start testing. It's a very simple system.
S-wire to the solenoid should only have voltage while the key is in the start position. Check that.
Solenoid should only be switched while the S-wire is hot. Check that.
Starter should only have voltage if the S-wire is hot and the solenoid is switched. Check that.
mattdel is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
landomar2014
08-17-2015 04:27 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
landomar2014
08-11-2015 06:39 AM
Quick Reply: Car stuck cranking
