[power steering fluid change
Old 08-09-2012, 10:37 PM
hashpipe956
hashpipe956's Avatar
Default [power steering fluid change
what is the easiest or best way to change the power steering fluid in my fox
hashpipe956 is offline
Old 08-10-2012, 01:03 AM
mattdel
mattdel's Avatar
Take the return line off the reservoir and stick it in a bucket. Run the engine and feed new fluid into the reservoir at a constant pace until the fluid coming out of the return line is shiny new. Turn engine off, reconnect line, done.
mattdel is offline
Old 08-10-2012, 07:53 PM
hashpipe956
Default return hose
which one is the return hose
Old 08-10-2012, 08:15 PM
Boss_Hotrod
Boss_Hotrod's Avatar
The rubber hose connected to the bottom of the pump with a spring clip or worn clamp. Be sure to plug the hole before filing the reservoir for the flush.
Boss_Hotrod is offline
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
jpplaw
08-22-2015 09:29 PM
antipeterleague
08-18-2015 01:50 PM
Greyshot
08-15-2015 03:32 AM
Quick Reply: [power steering fluid change
