Brake issues please help!
Ive been having some brake issues with my 94 GT. When i bought the car it had a dual piston swap. The calipers wouldnt release all the way so the 2 fronts were always dragging. So i swapped it back over to the single piston calipers and now i have no pedal. I have to pump it atleast 4 times before i get any sort of pedal. I replaced the master cylinder and bled the crap out of all four corners. But still no pedal. Any ideas??
Needs more bleeding. Sometimes a vacuum pump and/or the 2 person bleed technique just won't cut the fat. Sometimes, you have to bring it to a shop with a brake system flusher, this is a unit that will hookup directly to the master reservoir and force fluid through the lines, forcing a bleed.
Yeah, but replacing the master introduced air into the very beginnings of the lines(unless you were smart and clamped the rubber lines at the wheels, this would create a hydro lock and no air would enter).
To properly bleed that out, you'll need to have bled it enough to use probably over a quart of fluid.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
