Overdrive
Old 08-29-2012, 02:04 PM
jagrobusto
jagrobusto's Avatar
Default Overdrive
My 1995 5.0L automatic Mustang shifts out of overdrive, then right back into overdrive after 3 seconds or so, during highway driving. I can predict at what spot it will happen. At times it happens only once and at other times it happens every few miles.
Please advise.
jagrobusto is offline
Old 08-29-2012, 09:43 PM
Venomantidote95
Venomantidote95's Avatar
Are you maintaining a certain cruise speed or not? Since it is electronic and relies on a number of readings to know when to shift, then if you are right on a certain speed/load then it can freak out and shift in and out of OD, other than that you could have a problem with the button on the shifter itself, or OD could be going out!
Check for codes from the transmission and go from there!
Venomantidote95 is offline
Old 08-31-2012, 11:03 AM
jagrobusto
jagrobusto's Avatar
Thank you for your response. Can I check the computer code even if the check engine light is not on?
Old 08-31-2012, 11:23 AM
Tony71502
Tony71502's Avatar
Yes you can.
Tony71502 is offline
CarrieS
09-01-2015 01:00 PM
erig94gt
06-11-2005 03:14 AM
BlackGT5.0
02-15-2005 01:05 AM
89stanglx
02-03-2005 11:17 PM
88_5.0
12-24-2004 04:17 AM
Quick Reply: Overdrive
