changing oil pump
Old 08-30-2012, 10:41 AM
javila2468
javila2468's Avatar
Default changing oil pump
don't be fooled by mechanics that say that you have to take out the engine to change the oil pump. i did it with just car ramps, unbolting engine mounts and putting a piece of a 2x4 between the motor mounts and k-member. i left the oil pan loose and on top of the k member, i just worked around it. a bit uncomfortable and requires alot of patience and a magnet. here are some pictures of how i did it.
if you have to change out the pick up tube...it can still be done without removing the engine or removing oil pan completely. PATIENCE and a smart thinking can get it done pretty easy
javila2468 is offline
Old 08-30-2012, 10:46 AM
javila2468
javila2468's Avatar
he are a few pictures. notice the 2x4 that i used to keep the engine lifted.
Attached Thumbnails changing oil pump-img_1021.jpg   changing oil pump-img_1025.jpg   changing oil pump-img_1026.jpg   changing oil pump-img_1029.jpg
Old 08-30-2012, 12:08 PM
Tony71502
Tony71502's Avatar
I actually changed my oil pan while the engine was in the car. It was a real pain with longtube headers, but I got it done. No ramps, just an engine hoist and lots of paitience.
Tony71502 is offline
Old 08-30-2012, 12:29 PM
mattdel
mattdel's Avatar
With the proper tools, removing the engine can often be faster than struggling on a creeper. But yes, it's possible.
mattdel is offline
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
97SN95GT
09-13-2015 09:45 PM
5.0 kevo
09-03-2015 06:24 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: changing oil pump
