Valve cover questions
Hey all
I got new aluminum valve covers last week, and both covers have the hole intended for the breather/PCV system (I think thats what it is). Now, when I look at the stock motor in the car, there isn't a hole on the passenger valve cover. The new covers do have baffles that I will be installing.
I know the driver side is the oil filler neck (correct?). Should I install a breather on the passenger side? How do I plug up that hole? I wasn't intending on running a PCV system, is it needed?
Thanks in advance for the help.
Over a breather, not much. PCV is designed to create a vacuum, allowing essentially guaranteed air movement in the block.
Breather does the same thing, only without the vacuum. Free flowing. Easier to clog if your valvetrain throws alot of oil, though. Can also prove to be a bit restrictive in engines with bigger strokes.
zanemoseley
09-06-2015 12:58 PM
