Intake Gaskets?
Intake Gaskets?
I just got my lower intake manifold in today. I've got Fel-Pro gaskets. The intake-to-head gaskets look good, but the front and rear gaskets (the ones that connect the cylinder heads together) are made of cork.
Should I go ahead and use the cork gaskets or use the black RTV stuff to seal it? Or both?
Use the cork but sort of glue it to the engine with RTV.
I prefer the silicon type end seals found in many Fel-Pro gasket sets.
Ford built the car with end seals on the intake, not just a gob of RTV, that should tell you something........
I haven't used the cork in many years, just using Ultra Blue, or equal, gives a better seal assuming you clean everything with brake cleaner first. It also makes assembly easier to get it right, and leak free.
