Cam Install
Old 10-27-2012, 08:11 PM
1990gtf
1990gtf's Avatar
Default Cam Install
Hello all, I am new to this forum. I recently purchased a 1990 GT. I've been lurking around learning the upgrades and reading a lot of how-to's. I recently tore into my engine and started upgrading everything but the bottom end. When I got to installing the cam, I didn't know that the crank spun 2 times compared to 1 time on the cam. So in reality istead of being TDC on the number one piston, it was technically BDC. However the dots on the gears were lined up where they need to be though. Question is will this hurt anything?
1990gtf is offline
Old 10-27-2012, 09:22 PM
dawson1112
dawson1112's Avatar
as long as the #1 piston is at the top of its stroke your fine . The cam is what determines weather its compression or exhaust. So as long as the Marks are lined up correctly you will be on the compression stroke.
dawson1112 is offline
Old 10-28-2012, 12:44 AM
tinman
tinman's Avatar
^^^^^^^^^^^^^^He's Correct^^^^^^^^^^^^^^
tinman is offline
Old 10-28-2012, 11:39 AM
Duncan_GT
Duncan_GT's Avatar
I wondered this same thing when I installed my cam. As long as the #1 cylinder was at TDC and you lined up the dots on the crank/cam gear (Crank being at 12 o'clock and cam being at 6 o'clock) then you're good.
Duncan_GT is offline
Old 10-29-2012, 09:43 AM
89fiveeight
89fiveeight's Avatar
The crank and cam gears can only bolt on one way. turn your crank until you can put the crank gear on with the dot straight up, and then turn the cam until the dot will be straight down. Then just put the gears and chain back on. When you bolt your heads back on, the pushrods will have all your valves open/closed as they need to be at TDC
89fiveeight is offline
Old 10-29-2012, 06:48 PM
1990gtf
1990gtf's Avatar
Thanks guys. I got the front of the motor all put back together and something just made me think about that. I searched around for info on that to no avail so I figured I'd just ask the guys that know for sure.
1990gtf is offline
Old 10-29-2012, 10:06 PM
Venomantidote95
Venomantidote95's Avatar
dot to dot good to go! unless you have a multi key timing set!
Venomantidote95 is offline
mtgldr
02-03-2024 09:00 PM
Luke9222
10-22-2015 11:55 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Cam Install
