94gt vert rear speaker question
Hey guys, in my vert I bought it came with a jvc headunit and some crappy speakers with the cone off of the tweeter. My front tweeters do not play and neither do my rear tweeters and midbass speakers I took them out and on my way to them I found my 2 amps and they were unplugged, so I plugged them in and nothing happened also I took my speakers out and plugged them up to a radio in a shop and the woofers played sound. so what's the problem? anyone know? my guess is my amps got water damage because my old top DID leak.
Posted from MustangForums.com App for Android
also my passenger side windowS will not go up or down. I can push and pull them up and the motor works any clue on that? and finally my driver seat rocks funny is that normal? I tightened the bolts down because they were lose is there more bolts to tighten?
Im guessing if it has a jvc head unit in it that is after market and whoever installed it disconected the factory amps to allow for some aftermarket amp . Probly tried to splice into the wires at the amps to get the speakers to work with the jvc. I pulled the whole factory amp crap out of my 94 put new speakers in the doors and trunk and ran new wire . It was pretty simple for me to do as I had all the seats and carpet out of the car because I replaced the carpet with new so I ran all the wires before I put the new carpet and seats in. The seats should have 4 bolts that hold it to the floor . There are also 4 torx head bolts that mount the seat to the floor bracket located on the sides just below the seat. If one or more of those are broken it will rock back and forth, or it could just have a broken frame.
As for the window if the moter runs when you hit the switch and you can pull the window up by hand then the gears in the drive moter are stripped and you will need a new moter for the window.
I have a New motor for the rear ill put it on the front one and try what you said thanks. and I was honestly about to do that with the speakers. and I think my seats can wait lol
musnicki
09-23-2015 07:11 AM
