Top engine build, Double checking! and question
Hey guys, on my 95 gt i am re-doing the top half. I just wanna make sure i got all the right parts needed for the job. PLEASE let me know what you think and if you have any suggestions!
Stuff I already have:
Trick flow Track heat Heads.
Trick flow Track head Intake. Upper/Lower
BBK 75MM Satin Throttle Body.
Things ill be getting.
24Ib Injectors.
Trick flow Stage 2 or 3 Cam
Maf( What MM should i get?)
Ford racing complete gasket set.
BBK Chrome short headers.
Smog pump delete.
SCT 4-Bank Eliminator Chip
Is there anything else i am forgetting to complete the job, ALSO is there any other tuners available for the 5.0 besides the SCT one sold on American muscle thats not to expensive. Please tell me what you think! THANK YOU!
24Ib Injectors.
Smog pump delete.
24Ib Injectors.
Smog pump delete.
24Ib Injectors.
Smog pump delete.
Make sure you get aluminum head specific gaskets. This will save you trouble down the road.
I doubt the SCT chip will be properly programed with a canned tune, and unless a local shop has the software to reflash the chip then you're screwed. The Anderson PMS tuning system is probably the best thing you can get. Don't cut corners with tuning it cost more in the future to fix your mess ups than just buying the Anderson first. Trust me on this!!!
Buy AFR stud bolts for the heads they're much better than standard head bolts and have less tendency to back off over time.
You do not need fuel rails, your stock rails will support up to around 450-500 bhp.
Motor mounts, new water pump, and timing chain assembly would be an extremely wise decision. These don't cost all that much and again, can save trouble down the road. Do the job once and do it right.
A 110lb hr or 155lb hr fuel pump would be a wise investment as well to help meet your new fuel needs.
I like the water pump, timing chain sugestion. I'd call trick flow about the cam. They dont recomend the stage 3 cam. The stage 2 will probably fit. Dont want your valves smacking your pistons. So give TF a call.
Don't buy an MAF, but a 94/95 Cobra ECU. Works, much, much, much better with 24lb injectors as the ECU is mapped for those injectors. The after market MAFs all run rich.
Don't forget to pick up a new set of hydraulic roller lifters, it's always a good idea to replace these when there's a bunch of miles on them. Also, I would upgrade to hardened push-rods as well. I believe the Trick Flow Stage1 camshaft revs a good bit higher than the factory GT.
I just wanted to get in these few suggestions before you finalize your budget. I hope this helps!
Shane
Shane
HIS S-197
08-10-2015 05:47 PM
